CiscoWorks Prime 4.1 - Port speed report
I'm attempting to extract Link Speed reports from LMS for ADSL interfaces on 887VA routers.
I've created a Custom Report Template (Type Inventory) with rules:
     Interface:Type:equals:aal5
     AND:Interface:Speed (Mbps):=:All
The report runs but the speed value returned for the DSL interfaces is always 1 or 0. Removing the first rule (type equals aal5) so that the report runs for all device interfaces returns correct speeds for ethernet interfaces (100m).
Running a Detailed Device Invenetory report captures and dsipalys the correct speed for DSL interfaces that I'm after but the format is'nt very usable - too much extraneous info.
The DSL speeds captured by LMS would all have values with a decimal point e.g. 0.256M, 0.384M, 1.117M so maybe the report designer has a problem with handling the decimal place ?
Any suggestions  / workarounds appreciated.
Neil
326
