CiscoWorks Process Status
I have two processes that are always in the down state, DFMCTMStartup and DataPurge. Are these only invoked when needed? Which would then mean that their normal state is down. If not, what needs to be done?
Re: CiscoWorks Process Status
These processes can be down in normal operation. This is nothing to worry about. You should not try to start them manually.
Thanks.
130
