10-16-2007 04:57 AM
The odbc.pl and snmp.pl processes are failing on our CW Windows 2000 server. I tried stopped and restarting the CiscoWorks Daemon processes and rebooting the server - no luck.
Any assistance would be greatly appreciated.
Bob Schlifke
10-16-2007 08:35 AM
look at this thread if you are running into the same bug:
10-16-2007 08:42 AM
I was able to rename the cwsnmp.dll to cwsnmp.dll.orig and the Server Self-test no longer lists snmp.dl as failed. The odbc.pl failure message can also be ignore.
Thanks!
