Ciscoworks Products Update window doesn't, well, update
Running LMS 2.5.1 on Solaris. Ever since I upgraded to 2.5 last year, the new Product Update window (replaced the little scrolling window) has never updated.
I asked TAC about it and was basically told to forget about it. Does it work for anyone else or is it broken in 2.5+?
If it should work, how do I fix it? It seems the perl script looks for files that do not exist so some process must not be pulling them down.
  • Network Management
Re: Ciscoworks Products Update window doesn't, well, update
i running LMS 2.5.1 (windows) and I have the same problem.
I don't know about getting it to update on its own, but if you want to make manual changes look in this file:
CSCOpx\lib\classpath\com\cisco\nm\cmf\servlet\msgdir\downloadedCcoMsgFile
99
