ciscoworks red link
Actually one of the switch stack was down in the 3 stack switch. So i remove the switch and assign a diff ip to that sw but still the link is red even after refersh and topology update
1 REPLY
Re: ciscoworks red link
I assume you're talking about Campus Manager. Campus Manager treats stacks as one device, so if one member was done, you shouldn't have noticed any difference on the map.
However, if this was a cluster, simply removing a node doesn't delete it from the Topology Map. Right-click on the node that was removed, and select Delete Device.
121
