Webcast-Catalyst9k
CiscoWorks requirements
Checking the prerequisites to install CW LMS 3,2, I can note that there are two options, "With HUM" and "Whithout HUM".
Based on this, I would like to know if CW LMS 3.2 includes HUM or if it is a separate module that has to be purchase individually.
In the other hand, I have never work with HUM before, so I dont know what advantages does it have, and what useful options could it incorporate to a WAN enviroment.
Thanks for your help.
Re: CiscoWorks requirements
LMS 3.2 contains an evaluation license for HUM good for 90 days. After that, you
must get out your wallet. That applies to Service Contracts also. HUM is supported
separately.
Hi, as ryck said, HUM is included as trial version for 90 days. Is a separate license with which you can compile MIB's and then you can monitorize this variables.
After 90 days if you don't want to buy it, this is disabled and you don't have an impact with other modules.
168
