CiscoWorks RME 3.5
Software Managment upgrade process is failing on Cisco 2950T 24. The error generated is that the rename flash command failed. On looking at the debug report the command RME sent to the switch was "rename flash:+00:00 flash:filename" It appears that RME is reading the flash filenames as the timezone adjustment field rather than the actual file name. How can I get RME to read the correct filename.
1 REPLY
Silver
Re: CiscoWorks RME 3.5
Here is the User Guide for Resource Manager Essentials 3.5 follow the instruction as per guideline which may help you in software management :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/3.5/user/guide/ug_upgrd.html
118
