Webcast-Catalyst9k
CiscoWorks RME 4.0.6 Job Schedule
Is there some sort of guideline to how often RME should collect configs and inventory details etc etc?
Currently we do 'Daily' periodic collections of configs and 'Daily' Inventory polling, however I think it is a bit excessive for our environment.
We also have a slave CiscoWorks server which replicates the DCE and RME databases.
Are there some guidelines available in this space?
Re: CiscoWorks RME 4.0.6 Job Schedule
We typically recommend daily polling and weekly collection. If polling detects a change in either the config or the inventory, then a collection is forced. If not, you do not incur the overhead of a full collection.
As an alternative to polling, you could rely solely on syslog messages from devices. By default, RME is configured to listen for config change and inventory change syslog messages. In a stable network, these plus weekly collection may be all you need.
DCR master/slave only replicates DCR data. The RME data is NOT replicated. Typically for these kind of "HA" setups, we have recommended that customers turn down periodic polling on the secondary server. The secondary server should receive syslog messages, but the inventory and config change automated actions (previously mentioned) should be disabled. Discovery should NOT run on the secondary server unless there are devices which only it can reach. In that case, strict Discovery filters should be put in place to limit the scope.
If a disaster occurs, it is up to you to turn up polling, discovery, and the automated actions on the secondary server.
When you mentioned turning off 'Discovery' , I assume you mean in Campus Manager discovery?
Either Campus Manager Discovery or Common Services Discovery depending on which version of LMS you have.
We have LMS 2.6 so I take it to mean Campus Manager?
On the Primary server what level of Discovery do you recommend? Daily, once a week?
Depends on how often your network changes. You need to run Discovery every time you add a new device, or change a device's hostname.
152
