08-29-2013 06:06 AM
Hello.
We are using CiscoWorks LMS 3.2.1 on Windows. Can administrators compress the main folder CSCOpx?
Thanks.
Regards.
Andrea
08-29-2013 10:01 AM
It might work, the documentaiton is silent on it as far as I can tell.
I wouldn't advise it though. LMS generally only needs a couple of GB and is pretty performance-challenged when the underlying server hardware (including disk) isn't performing in top form.
09-04-2013 03:40 AM
Many thanks for your help Marvin.
Regards.
Andrea
