Webcast-Catalyst9k
puk
CiscoWorks shadow directory
I have selected "shadow directory" option after several days CW running. After selection only devices with changed configuration appears in the directory structure. What is the easiest way how to force CW to save configurations of all devices to shadow directory?
Thanks in advance.
Red
Re: CiscoWorks shadow directory
Unfortunately there is no easy way to do this. You can modify the config of each device, or re-init the RME database.
puk
I guessed that.
Thanks.
238
