Webcast-Catalyst9k
ciscoworks snms/ cat 2960
hello all
i have installed the latest upgrade (icl. latest idu's) of cw smns to be able to maintain configs and images of new installed cat 2960-switches.
whenever i check the device credentials, such as snmp-community-string e.g. via rme, i get the status "INCORRECT" for local user and telnet-password.
my questions:
is the support of cat 2960 integrated in these available upgrades ?
do i have to install some other packages ?
has anyone made the same experieces ?
any hint or tip is very welcome
thanks very much
roman
Silver
Re: ciscoworks snms/ cat 2960
2960 switches are supported only in RME 4.0.4. They are not yet supported by SNMS.
hello
thanks for your reply. do you have an idea about the timeframe for the support in cw snms
thanks again for your reply
114
