Community Member
ciscoworks upgrade
we have a pretty old version, 2000 LMS,
I want to upgrade it to new version.
Just want to get some advice before doing the upgrade?
Is there anything that I need to know before the upgration?
or any link would be appreciated.
thanks
H.w.
Re: ciscoworks upgrade
It really depends on what the older version of LMS you are running is and what version you are upgrading to.
You might want to look at these links which include upgrade, new install and data migration:
http://www.cisco.com/en/US/products/sw/cscowork/ps2425/prod_installation_guides_list.html
Community Member
thanks,
Is it free to upgrade?
The cost depends on what you purchased previously. Check http://www.cisco.com/upgrade/ . Enter your SAS contract number from CiscoWorks, and see if you are entitled to an upgrade.
Community Member
ping_admin
Community Member
beijing sino-bridgc.com
zhangyunping
zyp123
137
