Ciscoworks2000 when login, menu do not appear
I can login to the CiscoWorks2000, however the server configuration, RME, etc..menu do not appear.
Can anyone help?
Thanks.
Joe
Re: Ciscoworks2000 when login, menu do not appear
Which version of LMS are you running?
Does anything appear after you login? What browser version?
The version is CiscoWorks2000 5th edition windows and RME 3.4.
The browser is IE5.5 with Java 1.3.
I can login fine but the RME menu do not come on. I can only see the logout button, tha's all. I have attached a screen capture here.
Thanks, for yr help.
Check if all the services have started. Probably they are not started or are in the process of starting. Did you do a roboot or did you just installed the produkt?
This was installed about 3 yrs ago and there was no new package added recently. Rebooting the system did not help. I did a log file maintenance but that did not help also.
If you access the server by this instead:
http://10.250.1.22:1741
does it then work and display the menus?
Red
The menu picks are simply xml files located in
CSCOpx\htdocs\XML\System\maintree
Check the directory I mentioned above, and see if contains the following files for example:
aux-rme.xml
z-rme.xml
z-rmeconfig.xml
If they are not there, you may have to re-install RME.
No the result is the same
Has this ever worked? Did it recently start failing?
Yes, it has been working for the past 3 years but this problem came up just last week.
Red
aux-rme.xml
z-rme.xml
z-rmeconfig.xml
140
