CiscoWorls LMS 2.5 and SNMP community string
We want to change the community string in all our switches and routers.
Can I do the chnage in CiscoWorks globaly or I need to change each switch/router individualy.
Re: CiscoWorls LMS 2.5 and SNMP community string
You can change the community strings or any other device attribute globally in LMS 2.5 by going to:
Common Services - Device and Credentials - Device Management and then selecting a group in the tree or multiple devices and clicking the Edit button
Just make sure that when the next page loads you don't highlight any device in the left hand pane, leave them listed as is or it will only update the one device highlighted
Dave
Red
If you mean you want to reconfigure your devices, then you may use NetConfig to do so.
For additional information:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_4_x/4_0/u_guide/netcfg.htm
145
