Community Member
Clean Discrepancy Reports in LMS 2.6 CM 4.0.6
How to clean Discrepancy Reports in Campus manager because I fixed problem from node site but didn't reflect in Discrepancy Reports
Silver
Re: Clean Discrepancy Reports in LMS 2.6 CM 4.0.6
Hi ,
Physical Discrepancy Reports connects directly to ANI Server db, so the only way to clear this reports is reinitializing ANI database:
ANI - reinit ANI database:
To reinitialize the database in Unix:
# /etc/init.d/dmgtd stop
# /opt/CSCOpx/campus/bin/reinitdb.pl -restore
# /etc/init.d/dmgtd start
Note: First of all check for the file in your system
# find /opt/CSCOpx/ -name 'reinit*'
To reinitialize the database in NT or Windows2000:
# net stop crmdmgtd
# perl C:\PROGRA~1\CSCOpx\bin\reinitdb.pl -restore
# net start crmdmgtd
**For Campus Manager 3.3, the reinitdb.pl script is located in CSCOpx/campus/bin
directory.
Hope it helps you.
satish
This is very bad advice. Reinitializing the ANI database will cause you to lose all topology and user information and may not actually clear the discrepancy. If the discrepancy is truly fixed, simply re-discovering or re-data collecting the network will be sufficient to clear it. If that does not work, there is a device instrumentation issue or a bug in Campus, and reinitializing the database will most likely not help.
Typically, if the discrepancy has been fixed on the network, all you need to do to clear it in Campus is run a new Discovery (Campus 3.x) or a new Campus Data Collection (Campus 4.x). If the discrepancy remains after that, there is most likely an SNMP issue on one of the associated devices that is causing Campus to think a discrepancy still exists.
For example, if you're seeing a BPDU Guard discrepancy on 2950 switches, that is related to the bug CSCsg01956.
108
