Community Member
CM User Defined Group mempership not stable
I have LMS 2.6 with CM 4.0.6,I create 5 user defined group,I am facing unstability problems, sometimes I go to CM topology I didn't found any device in this groups, I return back to CM group admin,then I edit the group I found the devices then I click finish then everything work fine.
The last problem I face it was now the user defined group has the all discovered devices not only the memper devices.
Any advice
Thanks in advance
Re: CM User Defined Group mempership not stable
Debugging grouping problems can be tricky since it is not very easy to enable debugging. However, you can check the CampusOGSServer.log when you are experiencing a problem with the membership computation to see if there are any associated errors. If not, it may be best to open a TAC service request so that they can guide you through enabling and disabling OGS debugging.
Community Member
Thank you for this update
