02-04-2008 03:45 AM
in LMS 3.0.1 with CM 5.0.2 the command: cmexport ut -u user -p password -host makes the following output and the file is empty:
log4j:ERROR No appenders could be found for category (com.cisco.nm.ani.clients.u
tng.application.UTDataManager).
log4j:ERROR Please initialize the log4j system properly.
License warning message:
Username:user
ERROR DEEUTProcessor: Problem in extracting data from UT Serverjava.lang.NoSuchF
ieldException: UserName
XML Data successfully stored in file C:/PROGRA~1/CSCOpx/files\cmexport\ut\20082
4123337ut.xml
In LMS 3.0 it worked, also the l2topology export works in 3.0.1,
but the ut not
regards
Alex
02-04-2008 11:57 AM
This is a bug. I have created a patch for it, but you will need to open a TAC service request to get it. Have your engineer contact me directly for the patch.
02-04-2008 11:18 PM
ok thnaks, i will do it
03-12-2009 03:28 AM
What is the BugID for this one? I cannot find it in the BugTool.
Is it correct, that LMS 3.1 (CM 5.1 ) does have the patch built-in ?
03-12-2009 04:24 AM
That's probably CSCsm63631, upgrading to
CM 5.0.3 solved the issue for me, and it did not reappear in LMS3.1
03-12-2009 09:42 AM
Correct, that is the bug. On top of that, there is also CSCsq21297 which is fixed in CM 5.0.4 and 5.1.
