cmexport ut in LMS 3.0.1 fails
in LMS 3.0.1 with CM 5.0.2 the command: cmexport ut -u user -p password -host makes the following output and the file is empty:
log4j:ERROR No appenders could be found for category (com.cisco.nm.ani.clients.u
tng.application.UTDataManager).
log4j:ERROR Please initialize the log4j system properly.
License warning message:
Username:user
ERROR DEEUTProcessor: Problem in extracting data from UT Serverjava.lang.NoSuchF
ieldException: UserName
XML Data successfully stored in file C:/PROGRA~1/CSCOpx/files\cmexport\ut\20082
4123337ut.xml
In LMS 3.0 it worked, also the l2topology export works in 3.0.1,
but the ut not
regards
Alex
Re: cmexport ut in LMS 3.0.1 fails
This is a bug. I have created a patch for it, but you will need to open a TAC service request to get it. Have your engineer contact me directly for the patch.
ok thnaks, i will do it
What is the BugID for this one? I cannot find it in the BugTool.
Is it correct, that LMS 3.1 (CM 5.1 ) does have the patch built-in ?
That's probably CSCsm63631, upgrading to
CM 5.0.3 solved the issue for me, and it did not reappear in LMS3.1
Correct, that is the bug. On top of that, there is also CSCsq21297 which is fixed in CM 5.0.4 and 5.1.
148
