11-04-2014 08:45 AM
I ran CNA 5.5 up until last week when Java 7 71 update hit. When I tried to launch, I received JVM Not Found, that was all. So I figured it was time to install CNA 6, however during the install process I now get a pop up box stating InstallShield Wizard will not install with a JVM not found message. No other error messages, no logs, and the installation ceases. Tried installing CNA 5.8.9.1, and CNA 5.5 again, all stop at the same point with the same message. Anyone else see this issue?
11-05-2014 07:28 AM
When you start Network Assistant, Java determines whether the resources it needs are available. If they are not, Java displays the message Could not create Java Virtual machine, and the session ends. To overcome this problem, open the file C:\Program Files\Cisco Systems\CiscoSMB\Cisco Network Assistant\startup\startup.properties (the default installation path), and modify this entry:
JVM_MAXIMUM_HEAP=1024m
Replace 1024m with a lower setting that does not exceed the available RAM. There is no way to foresee what value will work. Try 512m , and lower it further if necessary. You can use the dial peer tag range 2500 to 2999 out-of-band to define your own dial peers.
Source: http://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_network_assistant/version6/relnotes/ol32368.html#pgfId-840748
11-05-2014 07:36 AM
11-05-2014 09:26 AM
Have you tried installing as the local admimistrator?
11-05-2014 09:32 AM
Local and Domain admin both, same results.
08-05-2015 10:19 AM
Hey Bob,
Did you ever find a solution to this problem? If so could you please share because I am having the same issue. Thanks
08-05-2015 10:24 AM
I ended up re-imaging my machine. However, when installing you must run the install as administrator, which then puts the program into the administrator's profile. Really strange behavior.
