CNA and a 4507 Switch
I have CNA 4.1 installed and I am trying to connect to a 4507 switch with IOS 12.2 (20)EW4. All of the modules should be supported, but when I try to connect to it I get an unsupported device error. Can someone please help?
Red
Re: CNA and a 4507 Switch
Make sure that you have the proper image (html files) loaded on the switch, and that ip http server is enabled.
Thanks for the quick reply! Do I have to have the HTML files loaded in flash to use CNA or only if I want to use the HTML interface through Internet Explorer? I had this same problem at my last job about a year ago and I can't remember what I did. Maybe I did load the HTML files. Please advise.
Red
I believe you are required to have the HTML files for CNA to work properly.
make sure that you have enabled http server on the switch
124
