11-14-2013 09:32 AM
I am trying to connect a NX7000 in the CNA(Cisco Netwrok Assistant) but it is failing. I checked the http settings on the NX7000 but it wasn't enabled. I tried to enable it but looking for the http feature but that feature isn't available. My question is, how do I enable the http on the NX and is the NX7000 approved device that the CNA will poll?
Thanks in advance, ~sK
Solved! Go to Solution.
11-14-2013 11:24 AM
Cisco Network Assistant does not support any of the Nexus products.
See the release notes for supported devices:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_assistant/version5_0/release/notes/OL12210a.html
11-14-2013 11:24 AM
11-14-2013 11:27 AM
Disappointed that it doesn't!
Thanks for the response, Marvin!
Best, ~sK
11-14-2013 11:55 AM
You're welcome. Most Nexus deals have a license for DCNM bundled. I often see this where customers don't end up installing the DCNM they are entitled. It's a full featured network management application for the data center products.
