Webcast-Catalyst9k
CNA can not manage 4506.
I am using 3.1 V CNA. When I want to add my cisco 4506 to community , I recieve "WS-C4506 is not supported as community member.". I read the doc, CNA must be support 4500 series. Http server is enable on the switch(default is disable). IOS is 12.2. CNA version is3.1.
I can control 3750 series switch and AP1231 Wireless devices via CNA. Do anybody know this issue and solution? Or what is missing?
Red
Re: CNA can not manage 4506.
For the 4500s you must be running the minimum IOS 12.2(20)EWA:
http://www.cisco.com/en/US/products/ps5931/prod_release_note09186a008051d2cf.html
I tried 12.2(20) with no success.
Had to upgrade to 12.2(25)ewa5 for it to work.
I wonder if there is a typo on the instructions?
500
