CNA Help !
Hi Cisco,
I have some basci questions regarding CNA with which I am much familiar.
1. I am using CNA v5.3 and would like know if it is the latet one or is there any later/ latest version available for download / upgrade.
2. Can we check using CNA about an interface which end host is connected to it.
3. Can we find using CNA that, where is the other end of a cable is connected to (which device or end host).
4. I have only four devices added to it and I am not able to add a c4006 with CatIOS to CNA. what is the procedure?
5. Do we have to configure device also before adding it with CNA.
6. Does Java also play anyrole on client machine with CNA and if yes then which version.
Thanks for any suggestions.
142
