Webcast-Catalyst9k
CNA login issue
hi,
How can login to tacacs configured devices through CNA.
I tried HTTP authentication it diesnt work
plss help
Re: CNA login issue
You need to use :  ip http authentication tacacs, as CNA communicates with the switch over HTTP.
Make sure to remove Ip http authentication local
Re: CNA login issue
hi,
thanks, I managed to login but now real issue is its showing unsupported device.
Switch   Ports  Model              SW Version              SW Image
*    1   26     WS-C3750-24TS      12.2(25)SEE3            C3750-IPSERVICESK9-M
     2   52     WS-C3750-48TS      12.2(25)SEE3            C3750-IPSERVICESK9-M
thanks
Hall of Fame Super Gold
Re: CNA login issue
Re: CNA login issue
hi,
thanks, CNA 5.5...I managed to login now the issue is showing unsupported device.
Re: CNA login issue
I'm seeing this same issue.  Local authentication works fine but as soon as aaa is enabled the device is 'unsupported' by cna.  I believe it is possibly related to the switch ios version, 12.2(25) as it is working on slightly newer revisions, 12.2(46) for example, on other switches but I'm not able to upgrade anytime soon to test.
679
