Community Member
CNA SmartPorts and custom Macros
I'm trying to discover if CNA Smartports support only built-in Cisco macros (ie "Desktop", "IP Phone+Desktop", "Switch", "Router" and "Access Point"), or if it can recognize and apply custom macros.
Custom macros generaly don't appear in "Modify Port Roles" window CNA-Smartport window, but when I embed the "Macro type : default interface" at the beginning of the custom macro, it appears in CNA-Smartport and can be applied (although variables are not parsed by CNA). I've found no documentation at Cisco about this "Macro type" command...
Any help ?
Gian-Paolo
Community Member
Re: CNA SmartPorts and custom Macros
Here follows a custom macro I created; it appears in CNA-Smartport window ("Modify Port Roles" scroll list), but CNA doesn't request user to enter a value for variable $access_vlan.
Tests have been run under CNA 4.1 and 5.0 .
#sh parser macro name Testing
Macro name : Testing
Macro type : customizable
# macro keywords $access_vlan
switchport access vlan $access_vlan
switchport mode access
Community Member
I have the same issues creating smartport macros. Do you have a solution for the issue, yet?
Volker
423
