Command syntax to remove read-write and read-write-all strings from CatOS -
What commands do I use to remove the read-write and read-write-all strings from a CatOS switch?
1 ACCEPTED SOLUTION
Re: Command syntax to remove read-write and read-write-all strin
You can clear these strings with the following commands:
set snmp community read-only
(SNMP read-only community string cleared)
set snmp community read-write
(SNMP read-write community string cleared)
1 REPLY
604
