Common services 3.1.1 Process problem
Some of the process such as CS Discovery,EDS-TR,FH Purge task,in common services 3.1.1 are never started and also transient terminated even though when i manually go and start them.
CVDeviceSelector.log is not rotating after specifying in below command:
NMSROOT\bin\perl NMSROOT\bin\logrot.pl -c
for rotation:running logrot
D:\progra~1\cscopx\bin\perl D:\progra~1\cscopx\bin\logrot.pl -s
Attached is the log file for process of LMS 3.0.1 with common services 3.1.1
1 ACCEPTED SOLUTION
Re: Common services 3.1.1 Process problem
No, EDS-TR should never run, and FHPurge is only run periodically. It is quite common to see it as never started.
These process should be down in normal operation. CSDiscovery is a transient process that only runs when a Discovery is running. When Discovery ends, the CSDiscovery process will be in transient terminated. Do NOT try and start these processes manually.
Start a new thread for the logrot question.
Hey Joe,
what about EDS-TR and FH Purge process they are shown as never started though i have seen them as normal operation before facing this problem.
thanks
141
