Webcast-Catalyst9k
compare with MRTG and 7606-S router for traffic
Hi ALL
I got very curious problem about traffic.
now our customer is using MRTG for monitoring network traffic.
but it has a different traffic amount between them.
Our 7606-S router records around 5.0Gbit/sec but when we check traffic in MRTG, it records around 3.0Gbit/sec.
We are using TengigabyteEthernet port.
I used at the below command.
- show int te3/1
- show int te3/1 accounting
- show int te3/1 counters
- show int te3/1 counters storm-control
- show int te3/1 counters errors
- show int te3/1 states
- show int te3/1 status
- show int te3/1 summary
and this is our diagram ...
[ISP] - - - - [OpenIX] - - - -  [Our router 7606-S] - - - - [CoreSW]
                        <--------------->  this area has a problem because the TX rate too much ...than MRTG traffic.
If MRTG show the traffic amount 3.0G bit/sec, also our router shows at the smae traffic amount when I typed show int te3/1.
but they have a different traffic amount......
How do I solve this problem? Please let me know and if you know that leave some message for me.!!!!
this is our Ten Giga interface ....
Router-10G-KRN#sh int te3/1
TenGigabitEthernet3/1 is up, line protocol is up (connected)
  Hardware is c7600 10Gb 802.3, address is x.x.x.x (bia x.x.x.x)
  Description: LINK-TO-OPENIX
  Internet address is X.X.X.X
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 129/255, rxload 23/255
  Keepalive set (10 sec)
  Full-duplex, 10Gb/s
  input flow-control is off, output flow-control is off
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1d02h
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 909411000 bits/sec, 1252934 packets/sec
  30 second output rate 5077415000 bits/sec, 2175391 packets/sec <-- too much output traffic . it's 5.0G bit/sec.
  L2 Switched: ucast: 126397661 pkt, 11020803633 bytes - mcast: 1984786 pkt, 142837100 bytes
  L3 in Switched: ucast: 62204465709 pkt, 5678022265563 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 108066369461 pkt, 30749529754908 bytes mcast: 0 pkt, 0 bytes
     62258838260 packets input, 5682471779406 bytes, 0 no buffer
     Received 2032799 broadcasts (690781 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     107880492952 packets output, 30703917284590 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
412
