compliance check issue
Dear all,
I try to do compliance check via two command line as below:
1.spanning-tree vlan <VLAN ID> priority <priority value>
2.ip tacacs source-interface vlan <switch_management_vlan_id>
but it is failed.
Is anyone can help me how to do it?
1 ACCEPTED SOLUTION
Re: compliance check issue
"Vlan\d+" is a regular expression which means match the literal string "Vlan" followed by one or more digits.
I assume you're using RME? If so, what version? What does your compliance template look like? What error do you get trying to test for compliance?
yes,I'm using RME.Version is 4.0.5.
i express unclear.In fact the job display successed.
my question is the command already setup in switch but when compliance check can not found it(need setup it)Please see attachment
two command:
spanning-tree vlan priority
It looks like you're trying to check for these commands in global mode. Please export for compliance template to an XML file, then post that XML file.
hi,
Yes you are right.it is global mode.
XML please check attachment
This template checks out. Though typically we would not see spaces in the variable names. For example:
+ spanning-tree vlan [STP_VLAN] priority [PRIORITY]
+ ip tacacs source-interface vlan [switch_management_vlan_id]
Let's see the config from one of these non-compliant switches.
Thanks for your help!
Now command
+ spanning-tree vlan [STP_VLAN] priority [PRIORITY] is ok
But + ip tacacs source-interface vlan [switch_management_vlan_id]
still is unavailable.the switch config as attach:
The problem is Vlan301 is one word, and you are treating it as two. Try:
+ ip tacacs source-interface [tacacs_source_interface]
Or:
+ ip tacacs source-interface [#Vlan\d+#]
Thanks for your strong support!
That's solved.
Would you please tell me what's mean "d+" in the command line.
227
