Compliance Checking RME 4.0.4
Does anyone know when newer versions of RME will come out to fix a number of problems one being the compliance checking feature.
Miron
Re: Compliance Checking RME 4.0.4
RME 4.0.4 has numerous fixes and improvements for Baseline Compliance, and I have fixed two additional problems in it since then (namely CSCse01353 and CSCse09832). To which problem do you refer?
Silver
I have created some reports in version 4.0.4.
They work as expected.
As always there is plenty of room for improvement.
Cheers
Michel
133
