Compression monitoring via SNMP
I'm looking for a MIB that allows me to get the compression ratio that is part of the output of "show compress" ...
show compress
Compressed bytes sent: 317862131 bytes 61 Kbits/sec ratio: 12.870
Compressed bytes recv: 221975672 bytes 43 Kbits/sec ratio: 9.194
... via SNMP. I'm talking about a serial interface with HDLC encapsulation and compression actived with the "compress stac" instruction. Any ideas?
Thanks in advance.
Thomas
1 REPLY
Bronze
Re: Compression monitoring via SNMP
you can check the CISCO-COMPRESSION-SERVICE-ADAPTER-MIB.
113
