Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
config management using telnet
Since I reinstalled CW, telnet doesn't seem to work anymore. CW always uses tftp or another procotol. telnet is always first choice in the admin section. When I do a telnet from another app it works. What could be wrong in CW ?
My system runs on Sun Solaris 8
Many thanks,
Lieven Stubbe
Belgian Railways
1 REPLY
Re: config management using telnet
Try removing everything except telnet from your transport protocols. Then enable a packet capture to determine what is happening when RME is telnetting to the device. Use Follow TCP Stream in Ethereal/Wireshark to read the TCP output in the packet capture.
you could also turn on debugs for archive management and look at the dcma logs
96
