Config Retrieval Schedule Question -
getwithrob
Level 3
Level 3
RME > Admin > Configuration Mgmt > General Setup - Change Probe Setup tab:
Config Retrieval Schedule is set to for Every day starting at midnight.
Is there anywhere to get a list of exactly what time a particular device(s) was actually hit?
nhabib
Level 9
Level 9
Check the /var/adm/CSCOpx/log/daemons.log and see if there is record of it there (they would start with NMCS).
If not, you will have to set up debugs of some kind.
miheg
Level 5
Level 5
If you enable the specific debuging for the config fetch you should be able to see it.
Michel
nhabib
Level 9
Level 9
