04-18-2006 09:41 AM
RME > Admin > Configuration Mgmt > General Setup - Change Probe Setup tab:
Config Retrieval Schedule is set to for Every day starting at midnight.
Is there anywhere to get a list of exactly what time a particular device(s) was actually hit?
Solved! Go to Solution.
04-18-2006 10:25 AM
Check the /var/adm/CSCOpx/log/daemons.log and see if there is record of it there (they would start with NMCS).
If not, you will have to set up debugs of some kind.
04-18-2006 10:22 AM
If you enable the specific debuging for the config fetch you should be able to see it.
Michel
04-18-2006 10:25 AM
