Configure mozilla 1.7 on HPUX to launch lms2.6 installed on solaris
Hi folks!
I would like to launch, from an HP-UX machine 11.00, a mozilla borowser pointed to sun solaris machine where running LMS2.6
From HpUx 11 propmt I launche the command:
# mozilla "ipcw2000sun:1741"
The borowser star correctly (login, navigation, ecc running ok)
but...
When I open an application, which need jpi1.4.2.10, the windows show a white background.
So:
- I've installed the jpi 1.4.2.10 as requested.
- I linked the jre1.4 plugin to the mozilla plugins directory.
So.. the topology services doesn't start e no notification appears!!
Any helps?
TKS
Leonardo
David Stanford
tks davistan!
it's strangge, because in the previous version of LMS 2.2, we were able to launch LMS 2.2 web client interface from an hp-ux client machine!
Did LMS2.2 compliant with mozilla client before?
Leonardo
Yes, but we were using a different plug-in version there. In LMS 2.5+, we moved to JPI 1.4.2, and you must be using the EXACT same plug-in version on your client that we support (e.g. 1.4.2_10). Beyond that, Campus is pure Java, so if the plug-in versions match, ut _should_ work. However, Dave is right, we never tested LMS 2.5+ on HP/UX or AIX, so there's no telling what will happen.
