Configure Speed and Duplex in LMS 2.5
I running LMS 2.5 and i want to configure the port speed and the port duplex for a Catalyst 3550 but i can't find how to do this.
I can do it with CNA or the web page of the device but how can i do with LMS ?
Re: Configure Speed and Duplex in LMS 2.5
you should be able to do this from within CiscoView or actually launch the tool to do it from CiscoView.
If you open up the device in chassis view and then right click (on the chassis) and select the option configure to open visual switch manager
Ok, but is it possible to do the modifications without launching anything else that LMS ?
I'm not sure that the visual switch manager is in the device and i want to avoid the cli.
You could try using netconfig or config editor which will use a GUI to push CLI commands to devices. Y
110
