Configuring a 6509 as an NTP Master
Everyone,
I'm having some issues with a 6509 that is configured as an NTP master. The clock is way off...right now, it's 11:35 AM and output below shows that it's ~02:46. Am I missing something?? How can I update the NTP master from the stratum 2 server??
Thanks!
MDF-LD1-6506L3-PRI#
MDF-LD1-6506L3-PRI#show ntp sta
MDF-LD1-6506L3-PRI#show ntp status
Clock is synchronized, stratum 2, reference is 127.127.7.1
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**24
reference time is C7D37639.988FD207 (02:45:45.595 central Tue Mar 28 2006)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.02 msec, peer dispersion is 0.02 msec
MDF-LD1-6506L3-PRI#
MDF-LD1-6506L3-PRI#
MDF-LD1-6506L3-PRI#
MDF-LD1-6506L3-PRI#
MDF-LD1-6506L3-PRI#show clo
MDF-LD1-6506L3-PRI#show clock
02:46:13.059 central Tue Mar 28 2006
MDF-LD1-6506L3-PRI#
MDF-LD1-6506L3-PRI#
MDF-LD1-6506L3-PRI#
MDF-LD1-6506L3-PRI#sh calen
MDF-LD1-6506L3-PRI#sh calendar
02:46:19 central Tue Mar 28 2006
MDF-LD1-6506L3-PRI#
MDF-LD1-6506L3-PRI#
1 REPLY
Silver
Re: Configuring a 6509 as an NTP Master
178
