05-31-2007 08:27 AM
Hi there!
After upgrading to LMS 2.6, I'm no longer able to configure a LAN port on a switch with CiscoView. All I get is an Error Message "Error on page", the changes are not acdcepted. I already tried with different IE Versions as well as different JRE versions.
Thanks for any advise!
05-31-2007 08:29 AM
What device and device package version are you using? Please try the same procedure with Mozilla instead of IE. Hopefully you will be able to reproduce the problem with Mozilla. In that case, putting "javascript:" in the URL field will bring up the JavaScript console, and provide more debugging information about this.
05-31-2007 08:59 PM
05-31-2007 09:33 PM
What is the configuration for the port you are trying to configure? I have a feeling the port description is breaking CiscoView.
06-06-2007 03:19 AM
The port description is blank and the same problem occurs with any action, taken on a interface e.g. changing duplex mode oder status.
Andy
06-06-2007 04:17 AM
Please provide a screenshot of the port config dialog as well as of the About dialog when viewing the device in question.
06-06-2007 05:00 AM
