configuring alerts on CW for power failures
I'm curious to find method to configure Power failure on several devices with dual power supply. Recently some devices had major power failure with no alarms triggered on Cisco Works.
Please hlep me.
Tnx,
Satya Singh
snip from 2 devices
6509:
Apr 29 %C6KPWR-SP-4-INPUTCHANGE: Power supply 2 input has changed. Power capacity adjusted to 1171.38W
Apr 29 %C6KPWR-SP-4-PSREDUNDANTMISMATCH: power supplies ratedoutputs do not match.
Apr 29 %C6KPWR-SP-4-PSINPUTDROP: Power supply 2 input has drop ped
Apr 29 %C6KPWR-SP-4-PSNOREDUNDANCY: Power supplies are not infull redundancy, power usage exceeds lower capacity supply
Apr 29 %C6KENV-SP-4-PSFANFAILED: the fan in power supply 2 has failed
Apr 29 %C6KPWR-SP-4-PSFAIL: power supply 2 output failed.
Apr 29 %C6KPWR-SP-4-PSREDUNDANTONESUPPLY: in power-redundancy mode, system is operating on one power supply.
Apr 29 %C6KENV-SP-4-PSFANOK: the fan in power supply 2 is OK
Apr 29 %C6KPWR-SP-4-PSOK: power supply 2 turned on.
Apr 29 %C6KPWR-SP-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system is operating on both power supplies.
3745
Apr %PS-3-MULTFAIL: There is more than one failure with the Power System 2; please resolve problems immediately
1 REPLY
Silver
Re: configuring alerts on CW for power failures
I think DFM should provide these sort of alarms. You should check if your devices are correctly configured in DFM.
In the automated actions of RME syslog you can configure your own alarms with stings like
*C6KPWR*
*PS*FAIL*
Michel
638
