01-14-2008 07:53 AM
Is there any to configure Net-SNMP to print the IP of the device in each returned line of a query?
For example, the following is the current default return when I query the ifAlias of a switch:
IF-MIB::ifAlias.12013 = STRING: 228A
IF-MIB::ifAlias.12014 = STRING: 228B
IF-MIB::ifAlias.12015 = STRING: 035B
IF-MIB::ifAlias.12016 = STRING: 053A
IF-MIB::ifAlias.12017 = STRING: 029A
IF-MIB::ifAlias.12018 = STRING: 125A
IF-MIB::ifAlias.12019 = STRING: 051A
IF-MIB::ifAlias.12020 = STRING: 203A
IF-MIB::ifAlias.12021 = STRING: 253B
IF-MIB::ifAlias.12022 = STRING: 212A
IF-MIB::ifAlias.12023 = STRING: 170B
IF-MIB::ifAlias.12024 = STRING: 253A
IF-MIB::ifAlias.12025 = STRING: 187A
IF-MIB::ifAlias.12026 = STRING: 064A
IF-MIB::ifAlias.12027 = STRING: 066A
IF-MIB::ifAlias.12028 = STRING: 252A
IF-MIB::ifAlias.12029 = STRING: 187B
IF-MIB::ifAlias.12030 = STRING: 191A
However, I was wondering if the output of this query can be configured to include the management IP address of the switch in each and every line of the above output.
01-14-2008 08:59 AM
Joe,
Do you know if this is possible?
David
01-14-2008 10:12 AM
There isn't an output option for net-snmp that will do this. You will need to buffer the output in a script or program then print out the lines with the added content.
01-14-2008 10:15 AM
That is what I thought. I have figured out within DOS out to buffer the output to a notepad text file. Now the next step will be to figure out how to write a script to add the content.
