Connecting to CiscoWorks TFTP Daemon
I am using CiscoWorks (Windows platform) for configuration backups. From a router, can I use the 'copy tftp running' command to restore a config from the CiscoWorks server? If so, what directory/filename do I specify? Where does the application store these config file backups?
1 REPLY
Red
Re: Connecting to CiscoWorks TFTP Daemon
Yes you may. Only thing is that you will have to copy the config into the CSCOpx\tftpboot folder first.
The default location of the configs varies depending on the version of CiscoWorks you are running. Which one do you have?
274
