Webcast-Catalyst9k
Contents of \NMSROOT\CSCOPX\tempBackupData
I am a tad bit pressed for storage (I know, I know, storage is cheap) and am wondering if the tempBackupData directory should be half a gig in size? Can I trim that safely?
Rob
1 ACCEPTED SOLUTION
Re: Contents of \NMSROOT\CSCOPX\tempBackupData
That directory can be purged provided you're not currently running a backup.
1 REPLY
110
