Blue
copy ftp behavior question
If I drop the password portion from the following, would I be prompted for the ftp password?
copy ftp://username:password@tftpserver/tftpboot/bin-archive/cat5000-sup2k9.8-4-2.bin disk1:cat5000-sup2k9.8-4-2.bin
The scp counterpart does.
Re: copy ftp behavior question
Its better to setup the username and password in the global config mode which will be used for doing FTP to the server.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800d9855.html#28514
regds
No, you won't get prompted. (Although it might still work if you've otherwise configured the username/password or if the server supports anonymous logins)
Andrew.
123
