Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CPI2.x - LMS feature question
When and with which CPI version could we count with this features:
1. AD/LDAP-User Integration (was in LMS)
2. extending ISE integration limit of currently only 1 pair
3. shadow config files (was in LMS)
4. edit Management IP (was in LMS)
5. can set Devicestatus UnManaged / Managed (was in LMS)
6. Threshold configuration in all Monitoring templates (custom SNMP, Interface Health ...) (was in LMS)
or will this be dropped generally?
thx for information, Steffen
1 ACCEPTED SOLUTION
Hi Steffen,
things you have mentioned are very specific with respect to LMS and PI . I understand these were one of the key feature in LMS ,not sure when they will be supported.
below  is the feature and functionalty matrix for LMS and PI:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/guide_c07-729089.html
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Steffen,
Thanks-
Afroz
Hi Afroj,
I know this matrix already. But the level of the document is to generic, to can answer the questions. Q3-6 are functionalities at very basic level and essential to can operate a network. That were basic features in LMS and even so basic features at competition NMS's from different vendors. Its not understandable to me, why it was forgotten to migrate this LMS basic functions to CPI in the perspective of product management.
I gave you the 5 points, because I appreciate your afort to keep the community with many answer to a lot of persons alive and let keep the community participating on the TAC-Knowledge arround Prime NMS products. It was just an answer, but not a helping answer:) But doesnt mater - I lost a lot of expectations regarding CPI's real ability of Cisco unified management. v2.0 is still just only a WCS upgrade.
Steffen
203
