crashinfo-how to enable it
vchoudhary
Hello All
I know that all Cisco routers are by default configured to create crashinfo file in the flash, now suppose if router is not creating that file, which command line I should use to enable that feature on Router? Help me on this please
Vishal
Richard Burts
Vishal
One of the primary things that prevent the router from creating the crashinfo file is not enough space in flash. Can you post the output of show flash, and verifying how much is available in free would help verify whether this is a problem.
Rick
Rick
