03-03-2014 07:39 AM
any idea if it possible to create a cli template to deploy access lists for switches and routers. It should be possible to define source and destination ip addresses as well as multiple line.
thanks in advanced
Alex
Solved! Go to Solution.
03-03-2014 08:33 AM
Hi Alex,
Yes ,it is possible. you can check the below link:
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
03-03-2014 08:33 AM
Hi Alex,
Thanks-
Afroz
03-03-2014 10:40 AM
thanks Afroz, you saved my day.
regards
Alex
