Critical Interface need to send Alerts
Is it possible to specify which interface to send alerts , for example uplinks only should be monitored for alerts?
How can I configure it , and in which module.
Regards/Asfar
1 REPLY
Re: Critical Interface need to send Alerts
If you only want to manage certain interfaces in DFM, you can unmanage the ones for which you do not want to get alerts under DFM > Device Management > Device Details. Set the managed state of the uninteresting interfaces to false.
140
