Community Member
CRS with CiscoView
We have LMS3.1,RME4.2,ciscoview6.1.8 and Integration Utility1.8.0 with the latest devices update but in CiscoView only we can't view the Cisco CRS-1 8-Slot Single-Shelf
System,SysObjectID:.1.3.6.1.4.1.9.1.643
The below message is appeared:
Message
Cannot find applicable device package for 10.1.0.41.
This error could be due to one of the following:
- The device package for this device type is not installed.
- Device support for this device type is not available.
- You are trying to open a component inside a device.
To correct the problem, either install a device package for the device type, or open the parent device to manage the component.
Re: CRS with CiscoView
The CRS-1 is not supported by CiscoView.
Community Member
even with LMS3.2 ?
Hall of Fame Super Silver
That's right - not even with LMS 3.2. See the LMS 3.2 supported device table here: http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/device_support/table/lms32sdt.html
As noted in the last two columns, CiscoView does not currently support any of the CRS models. (Campus Manager and RME DO support the various CRS-1 models.)
No, there will not be any CRS-1 support in CiscoView. Even the GSR support is being deprecated.
188
