CS 3.0.6?
I'm trying to update our LMS components...I know CS 3.0.6 is out, we're running 3.0.5. When I do the software update it downloads updates for all the components except for CS...and when I check for updates on CS alone it says no updates are found...but when I try to install updates for other components it says I need CS 3.0.6. Do I have to download this update manually from somewhere else?
1 ACCEPTED SOLUTION
Re: CS 3.0.6?
The CS 3.0.6 update contains crypto code, and cannot be downloaded like other Service Packs. To get it go to http://www.cisco.com/cgi-bin/tablebuild.pl/cd-one-3des .
Re: CS 3.0.6?
Re: CS 3.0.6?
ah ok got it...Thanks!
97
