03-16-2009 05:16 AM
I have a stand alone implementation of IPM. I add and subtract devices to CS as I need to work with them. I recently deleted all devices out of DCR and then an import of new, some may have been the same but it was a bulk delete, bulk import.
There are 8 out of the newly imported 1200 devices the DCR cannot find but when I try to add them manually or by csv they are counted as duplicate and not added. Catch-22
Any ideas on how to fix this?
03-16-2009 09:28 AM
Is this server integrated with ACS?
03-16-2009 09:39 AM
No
03-16-2009 09:41 AM
Are you getting an error in DCR stating that the device already exists when trying to re-add it?
03-16-2009 12:44 PM
No error message. It says the device doesn't exist. After I have gone through the motions of adding it, DCR tells me it is a duplicate device. Then when I query the device in Device Management, it says the device doesn't exist.
03-16-2009 12:51 PM
I would need to see a DCR export, and possibly some database information to analyze this further. I doubt you'll post that on the forum, so I recommend you open a TAC service request.
